Oil leaking at foot
  • Oil leaking at foot
    Hello...I have a Yamaha F150/TLRC and there is oil leaking out of the hole that is to the right of the foot oil level screw that is about 1/8" in diameter.
    engine oil or gear lube?
    that is the waterpump cavity drain.
    if gear oil the drive shaft or shift shaft seals, if engine oil either the drive shaft or oil pan gaskets.
    we do have some drive shaft seal issues in saltwater.
