Hi Folks
My power tilt has failed. I removed the stator and found that the magnets inside that should be glued to the case of the stator have come unglued.
I can't easily replace the stator assembly as I am out of country. Any ideas as to what kind of adhesive would hold the two magnets in place inside the stator permanently?
Also, according to the manual there's a circuit breaker inside the motor base someplace. Does it reset automatically if the power tilt motor overheats or does it "blow" like a fuse, rendering the motor base permanently defective?
If anyone has successfully re-glued the stator magnets back into the stator please let me know what you used for glue.
