Hello all, I'm new to the forum and am looking for some guidance on the proper location to set valve clearances on a T8. The service manual I purchased for the T8 has two different areas that discuss valve adjustment. Page 23 of the manual indicates the valve clearances "a" and "b" are set set between the valve stem and adjustment screw as shown on the following diagram:
On page 3-10 of the same manual, the diagram and instructions indicate valve clearance is set at the opposite end of the rocker arm, between the cam shaft and rocker arm:
When I set the valve clearances at one location, the opposite end is out of spec. Is there a Yamaha Mechanic that can confirm the correct valve adjustment location?
