My 95 250 2 stroke is smoking like a banchi at start up. I've experimented and left the engine vertical overnight and there is some, but a liveable smoke show the next day when starting. If I store it with engine tilted up, there is lots and lots of smoke. This leads me to believe the oil is draining into the airbox and is sucked in at start up. I have a Mikuni oil pump and removed it to replace the oring on the backside (didn't help, but couldn't get the spacer out to replace that oring). There is no sign of oil on any external part of the pump (even the back). Is there a check valve issue in the pump? if so, can it be fixed?
Thanks!
Thanks!
