I have 2 1990 model 90hp motors which only have done 80hrs since a rebuild, the motors were sitting around unused for a good 8yrs with regular start ups.
The motors ran fine while on the previous boat, now that i have them running on another boat they idle good and rev up freely but under load one was breaking down allot.
I stripped the carbys and rebuilt them only to run into major drahmas now
I done a compression test today on the port motor, The readings were 125psi, 90psi and 70psi
pulled the head off and found slight skuff marks in the bottom cylinder, I can still see the hone marks in the bores as well.
Starboard motor had readings of 30psi
, 125psi and 125psi, pulled the head off this motor and found the top cylinder has broken the piston ring and it has smashed into the piston and damaged the head slightly.
The motors were running cool on all cylinders, no hot spots were evident, oil injection pumps worked fine, I am yet to fully dissasemble the motors to further investigate the cause.
What may have caused this as they have done very little hours/work since being completely rebuilt by a marine mechanic
