Rpm 90 hp vs 50hp
  • Rpm 90 hp vs 50hp
    Replaced my 2006 50hp w/ a 1999 90hp and my rpms are off the gauge. With my 50 hp 4900rpm was tops. Now I'm at 7000(maxed gauge out). I have a propco 13/17p and I'm thinking I should be going faster than 32mph w/ the motor trimmed. Do I need to replace my tach or is there some different wiring set up? ANd I guess I need a higher pitch once I figure out how many rpms at WOT.
    the 90 is a 12 pole and the 50 a 6 pole, so need to change setting on tach
      thank you
      thx and I guess the tach has a switch or do I have to rewire somehow???
        Small slot head screw on back of tachometer with several different positions....
          dunno.
          who manufactured your tach?
            Rpm 90 hp vs 50hp
            Came w/ my 2006 Key Largo which had the 50 hp yamaha.
              That still does not say who built the tach or what model it is
