Leaking Tilt Actuator 70EGLT
  • Leaking Tilt Actuator 70EGLT
    Any recommendations on repairing or replacing tilt actuator on older engine that I bought used several years ago. Ive been maintaining the engine and runs well but the tilt actuator started leaking several weeks ago after I seviced it with a non yamaha brand oil. It worked fine for a while but started slowly leaking after a few weeks. Manual stated to perform full service and bleed when using other brand fluids. Shall I still try to do the full flush and bleed or is it bad seals because of an older engine? Reading an earlier post from the past a seal kit with special tooling was recommended any one know what special tooling was in the kit?
    You can take it to your dealer to have repaired, it's not hard if have tools.
