use sealer on pump diaphragm ?
  • use sealer on pump diaphragm ?
    guys,
    i have a 1988 yamaha 25hp two stroke.
    yesterday i installed a new fuel pump diaphragm and gaskets. when taking the original one off, the gasket was stuck onto the mating part only in a few spots. i could tell there was no type of sealer used.
    i installed the new gaskets and diaphragm i installed it dry, and when i primed the ball and started the engine it was leaking gasoline ever so slightly.
    should i have used sealer on the gasket ? will it "seal itself" in time ?
    thanks much
    no sealers.
    occasionally we have to surface the faces to make them flat.
      no sealers.
      thanks for the confirmation... much appreciated
