which grease are you referring to,, gear lube, or grease to hit the zerks... and why not use yamalube, it is cost comparable and why not use the manufacture product. I know i do.. anyway what ever you decide to use make sure it is marine grade, it has rust and corrosion inhibitors.
I use that Walmart brand Marine grease in my grease gun, for zerks, wheel bearings, etc. For extreme waterproof applications like drive shaft splines, prop shaft splines I use a tube of Quicksilver 2-4-C...it may be some better, but not absolutely sure...
I'm refering to zerks grease.
Here on my location I can just find the yellowish lical grease 225g/8oz tube.
I need some 400g/14oz cartrige so you can use it on my grease gun other wise I'll need to buy another grease gun.
I asked because can be some other grease that could be a good job also.
