I am switching out a 2006 yamaha 50ltr w/ a 1999 yamaha B90tlr. It seems the threaded rods on the cables which attach to the carbs linkage are not the right length. Are there linkage extenders or do I need to buy new cables?
carbs control linkage
Would need number 6 in this diagram, 1999 B90TLRX Yamaha Outboard CONTROL Diagram and Parts
control cable
It appears that the cable was not long enough from the point it fits into the crowling where it is held in place or at leat that is what I thought. I know the piece #6 hole was not big enough to slide onto the male connection point, but I figured I could drill the hole a bit larger in PC#6. how sure r u the cable is the right length? Just asking because I'm a novice!!!!!
Â
