I have a 2004 f90 tlrc. The carbs were removed, cleaned,by a yamaha dealer about a year ago, compression was checked, had stabil in fuel etc. I did not run the boat except right after the work was done, it ran fine. the boat sat and what i expected happened, ran rough, carbs needed cleaned. i removed and cleaned thoroughly, had to replace the pilot jet in the 1 carb(the top broke when removed) i counted turns for the needle valves and set them the same.
so i put it all back together and started, it started right up but i noticed smoke. i shut it down to hook up sync guage. started back up and still had smoke and rich smell shut down after a few minutes ,checked plugs and 2,3,4 were wet. checked oil and seems overfull so may be getting gas in it. looking for some guidance, any help is appreciated
