Tilt & Trim fluid drainage
  • Tilt & Trim fluid drainage
    How can I drain the fluid in the trim ad tilt unit? Please,
    I have a F225 TURB. SEAL WENT BAD ; it may has water in the fluid, fuid is a pink color
    while the rams are out suck out the bad ju ju from the cylinders.
      Thanks Rodbolt, I already have the nuts out, shal I pull the rams out?
