Yamaha four stroke 225hp 2001
  • Yamaha four stroke 225hp 2001
    I currently have 1300hrs on my 225hp four stroke. i never had issues until the last time i took my boat out. It stalls when i rev it up on the trailer now and when i was running in at 4200 the boat slowed a bit and then picked back up, it wasn’t a rough feel at all it just slower for a sec and sped back up. The motor also runs rough when it’s just in gear also. I change all the filter religiously and use a racor 10 micron fuel filter. i have always used ring free every fill up and when i leave the boat i use fuel stabilizer in the tank.
    I would appreciate any feed back as the boats out of the country and hard to find a Yamaha certified tech to look over the motor. I was thinking on changing the high/low fuel pump and VST but I’m just guessing!
    Clean vst filter
      Just the vst filter? I guess I will try that what else could it be so I can check if its not that. Thank you for your response
        while cleaning the VST I would also pull the injectors and at least flush the injector screens.
          thanks for the advise! hopefully its as easy as replaceing and or cleaning filters! thanks again
            if it was hard I would not do it for a living.
