Out of the blue my Starboard motor dropped 200 RPM pretty much all the way from idle to WOT. It will hold RPMs and I can synch with the port motor by giving it more throttle.
The motor has 350 hours and seems to run good, idles fine, and does not exhibit the symptoms of dirty mystery filters in the high pressure pump.
It just runs 200 RPM less than the port motor and it will not reach the 5200 RPMs that it used to. The port motor still hits 5200 at WOT.
I changed plugs and it ran great for about a mile or two, then it dropped down 200 RPMs below the port motor.
I notice that it smokes some at start up, while the port motor remains smokeless.
I am thinking low pressure fuel pump problems.
Any ideas are greatly appreciated.
