I have a 1993 Yamaha MSHR 25hp outboard motor (2 stroke). Recently it has started "bogging down" about a minute after reaching 3/4 to full throttle. Once it has "bogged down" from full throttle it will only move very slowly no matter where the throttle is. I am able to disconnect the fuel line and let the motor run out of fuel, once the line is reconnected the motor will run fine until 3/4 throttle is run for a continuous minute. Runs fine on the hose in the yard. I have changed spark plugs, fuel filter to no avail. Any information or suggestions would be greatly appreciated.
Thank You!
Peter
Thank You!
Peter
