Have 2 stroke 200hp salt water series II. Pulled spark plug out so I can do a compression test and one of the plugs came out like new. Other had slight black and greasy. What would cause a plug to look like new when it been in a running engine? ( I only replaced plugs couple of hour running ago) I would suspect this cyl. Has not been firing. Are there any valves between carb and that could fail Ina closed way?
Spark plug looks like new
May have an internal water leak on that cylinder, so when water flashes to steam upon combustion can have a "steam scouring" effect on that plug, causing it to be totally white. A bore scope into that cylinder may reveal the combustion chamber and piston crown to be shiny clean, with all carbon gone. If that's the case, then remove head to inspect for leak...hopefully may be just a bad gasket and not a pin-hole in metal casting...Good Luck!
[QUOTE=vanderwel;74174] What would cause a plug to look like new when it been in a running engine? ( I only replaced plugs couple of hour running ago) I would suspect this cyl. Has not been firing.QUOTE]
Clean plug as in looks new = cylinder not firing.
Check for spark on that cylinder.Might be as simple as a bad plug.
How did plug look that you took, before replacing when you changed them?
Curiosity - What has lead to the compression test?
Selling/Buying?
Poor performace?
thanks robert and muskrat,
the reason i went for a compression check is that the engine temp alarm goes off and engine slows to safe RPM. a new impellor has been fitted, new thermostats, new fuel filters, new spark plugs, ran the engine on premix fuel when alarm went to check if the oil injection was a problem, but all this work and problem still exists. hence a compression check to look at the cylinder condition. Im now thinking of a reed valve issue on the cylinder with the clean plug (but i cant find any info on these yet will keep looking though) ive only owned this boat for a couple months so im still learning the ins and outs of this engine. i have notice the engine has a vibration at lower RPM so the clean plug that explains that. Im keen to learn more about reed valves. will keep this forum posted on how i progress.
hi cold compression 800 - 900 (5 were at 900 and 1 at 800)
Hot compression all same at 800 - 850 had a look onto top of pistons with torch and they all looked same. rough, sooty, greasy film. no "clean" piston as such. I think the problem might be with a fuel blockage to one cyl.
and we still have no clue as to the fuel or ignition system we are disscussing.
by you language and use of the metric system I assume your not in the US market.
international market motors are sometimes very different than US market.
and thus is the reason I ask for model numbers.
ÂÂÂ
