Installation of water temp and pressure gauge in a VF200
  • Installation of water temp and pressure gauge in a VF200
    I need to know where I install the sender in the motor. The engine is a 2012 Yamaha VF200. The gauge part numbers are:
    688-83667-00-00 YAMAHA WATER PRESSURE SENDING
    688-83591-00-00 YAMAHA WATER TEMP SENDING
    Thanks.
    You will need to order new thermostat cover,
    WaterPortVF SHO.pdf
      Thanks....
      [ATTACH]969[/ATTACH]
        Is this alternate thermostat cover (that accepts fitting for water temp sender) available for a 2001 vz200tlrz? If so please let me know what the part number is.
        Thank you.
          The temp sender goes in port on top of engine block on the VZ200 models,
            on the VZ model the temp goes in the stbd side,water pressure goes in the port fitting.
            the VF motor is TOTALLY different than a VZ.
            its why thread hopping is discouraged.
              My 2001 VZ200 came rigged with a water pressure gauge and it's on the top of the block on the starboard side. Should I switch it to the port side and install the temp fitting on the starboard side?
