1989 Yamaha 115 Ignition Switch
  • 1989 Yamaha 115 Ignition Switch
    I'm not getting any juice through my ignition switch. For a few months I was able to start the engine with a push to start button (bypassing the key switch to start engine), but now the switch no longer works to shut engine down. Switch also seems to affect the oil transfer from remote tank to engine tank. What is the part number for the key/ignition switch? It is for a 1989 Yamaha 115 and is installed on a 1984 17' Boston Whaler.
    If it's a dash mounted switch then use 704-82570-10-00 Key Switch Panel,push key to choke
      It is dash mounted, but there is a separate toggle switch for the choke. The key does not push in for choke.
        Can't get the old style with toggle any longer, the new one will work just push key in to choke.
