Hi,
I've got a little problem with my 25HP. The selection of forward and reverse gears is an issue. I can select reverse no problem; however when I move from reverse to the neutral position on the selector, the motor stays in natural. Also forward only engines when I move the selector to the very end of forward position. I can get the motor to return to neutral by slowly pushing the selector towards the centre position from the forward position. The motor has had this problem for the past 6 months, but starting to think I should get around to fixing it. A friend thinks it could be a lower end problem (the dog). Can anyone help with advice or diagrams; I'm not too bad on the tools once I have an idea what to do.
Thanks..
Thanks..
