I have a 2005 T25TLRD made in 8/04.
So I ordered the tach for the 2005 and newer motor, as a T25TLRD is listed as a 2005 model, which has one plug. When I opened the control center I found that the old tach has two plugs and a two plug wiring harness.
Following this wire to the engine ends up with the two plugs not plugged into anything.
This is the only connector on the engine (besides the two from the tach) that is not plugged into anything. What is it used for?
The old tach works. So questions.
Do I just hook up the other non-plug connector wires on the new tach and forget about the plugged wires?
Do I need some kind of adapter cable?
What is the other non-connected connector on the engine used for?
Did this engine have push to choke and a tilt/trim sender?
Thanks!
Thanks!
