I own a small boat rental company.I am going to change the impeller on a Yamaha 2005- 60HP four stroke high thrust motor.
The shift linkage is a spline fit correct? So to remove the lower unit I just remove the 4 bolts and side it down? There is no shift linkage to undo?
Is there anything else I need to lookout for or special tools required.
Thanks for any help in this matter
David
David
