Shift Relay
  • Shift Relay
    Hello
    I have a 2011 250 which is not shifting and suspect a relay has gone as just before problem occured one of the relays was chattering in the fuse box at KEY ON.
    Of the 5 relays in the fuse box which is the shift relay and please identify the other relays. There was some corrosion in the relay box which i believe has caused the relay failure
    thanks Andrew
    What is model number of outboard?
      Hello
      Australian F250 DETX which is the same as your latest model F250.
      thanks
      Andrew
        Not familiar with that model number but if this is a digital throttle/shift model then there is a fuse and relay in fuse box.
          Originally posted by Andrew1970 View Post
          Hello
          Of the 5 relays in the fuse box which is the shift relay and please identify the other relays. thanks Andrew
          The USA Edition Owner's Manual has that info on page 97.
            Thanks guys
            Which relay in particular is related to the Electronic Shift
            Andrew
              Go to www.yamaha-motor.com and view owners manual for a F250BTXR model and it will show layout.
