Was running great then pulled into the dock and no reverse. Pulled shift cable from linkage and cable is fine but cant shift into reverse using linkage. I was thinking clutch dogs? I know i will have to pull and dis-assemble lower unit to find problem right???? 05 HPDI 225.
No reverse
no go
I tried to manually push it into reverse after removing the cable by using the shaft the cable attaches to and it wont slide back. It slides into fwd but not reverse. Am I missing something here? Do i need to pull the other cotter key and pull that shaft up?
ÂÂÂÂÂ
