Hello
I try to upgrade my boat with digital tach and speedo but have a problem to get the trim on tacho to work. I hope you experts in here can help me.
When I connect the harness from trim sender to the new tacho the trim bar goes to the top and the top bars blinking. ( when I connect back to the old one then the old one works, so it should not be a problem with the sender?
I am from Norway, so my engine is a european Yamaha 80hp type AET year 1987 with 703 remote control ( identical with 90AET except from carb id and exhaust manifold id) Not sure what name this type have in US. The tach have 4 single wires and 2 terminal block, I connect the 4 single wires to the harness from remote and the harness terminal from the trim sender I connect with adaptor between to the terminal block that have the pink, grey, orange and black w/whit stripe. The other terminal block on the tach I dont connect anything to since I dont have oiltank on my engine (this block is for oiltank sensors?), I add oil directly in gas tank. Anyone that have an idea of what I do wrong?
I attached some photos. I am not the best in english so I hope you understand what I have written.
Best regards from Norway
Björn
Björn
