what would a bad thermo sensor other than the cold start process
88 excell 225
what are the different failors when i first got the boat last year when i would start it up the idle would go up till it was warm then drop down 1200rpm then to 750rpm now just starts at 750
today i did some tests on the sensor that was the book it said at 68f it should be 61.6 kilohms and 3.3 at 212f i got 118.6 kilohms at 68f and 6.4 at 212f im thinking it is no good any thoughts
what effects would it have on the motor's performance? I'm also having some issues where it bogs or misses at high rpm, but doesn't happen all the time. Not sure if it's a fuel issue or sensor that is making it do it-
ÂÂÂÂÂÂÂÂ
