Want to buy a Water Pressure Gauge Kit
  • Want to buy a Water Pressure Gauge Kit
    I have a year 2000 F80 TLRY and I want to add a water pressure gauge to my console. I called boats.net and gave them my motor year and model but the guy was unable to find the gauge kit. Hoping someone can direct me as to what I need to get for the install. Ideally, I wanted a kit that had everything, but if I have to buy separate parts, thats fine to.
    A diagram for the install would be a big help as well.
    Thanks in advance.
    Dan
    6Y5-83660-10-00 Pro Series Water pressure gauge
    688-83667-00-00 Water pressure sender
    Here is port location on engine,
      Thanks, just put in the order.
      Dan
        Yes you can add them to shopping cart from that link on last post.
          I already have a Yamaha water pressure gauge on my 2001 200hpdi but the hose is now 12 years old and on it's way to becoming brittle. Does Boats.net sell that particular hose? Thank you.
            If it's a Yamaha gauge then use
            663-83668-00-00 Nut and ferrule
              Originally posted by boats.net View Post
              The complete gauge and associated hardware are installed and operating. What I need is only the clear hose that goes from the engine to the console. By the way, the water pressure gauge face (not the clear cover but the paper backing with numbers on it) has faded. Can I buy just that face or do I have to replace the gauge?
                Those parts number are for the tubing and ferrule needed to replace tubing. Would need to replace gauge if face is damaged.
