I have a 703 control that does not have power trim but has a 10 pin cable rather than the 7 pin that is used when no trim. It should still work, right? The extra pins just won't do anything?
Yamaha 703 7-10 pin
Is your motor 10 pin or 7 pin, does your motor have trim?
If the connector on engine is 10 pin as well then it will work, if motor has 7 pin harness then would 703-8258A-00-00 7 to 10 pin adapter harness
ÂÂÂÂÂÂÂ
