overheat on ful throttle only
  • overheat on ful throttle only
    94 85 hp overheats on ful throttle only,new water pump,head gaskets waterplate gaskets and cleaned head like new,please help!!!
    If didn't replace whole water pump then may need to replace hosing and a water pump repair kit. Check thermostat and pressure relief valve.
      Corey:
      Had the same problem after 18 years on my '94 75hp. The water passages were "Rocked up" with calcium. Tried all the Lime-away products. Not very good results. Diluted masons grade Muriatic acid 50%. Pulled thermostat and pressure relief valve. Let idle for half an hour in a tub. Flushed for an hour with water. Replaced thermostat and PRV. Did the trick. No more over heating. Yooho!
      Good luck, Dave
