Just installed F70 on 17ft mako and the top speed is 12mph and boat fails to plane. ha snew controlbox(new cables set properly) new gas tank ,lines,and seperator/filter. Starts fine, runs well just no speed. Today tried different height adjustment re cavitation plate, no improvement. Followed break in instructions. Please advise, would like to go at least 20mph!! Thanks
new f70 on 17ft Mako top speed 12mph!
The prop is AL 13 x 19 stock number is 6E5459410000 Thanks for your intrest. do not have rpm's Honestly didn't think I would need tacometer but will purchase and install
19 pitch prop is way to much, i just put a f70 on a 17 key west and put a 13 by 15, rpms are very important for propping a boat.
I'd look at using a 15 pitch prop MAX with that engine/boat combo. Might even consider a 14 or 13 4 blade. A 19 pitch is WAY too much prop for that set up.
Sequoiha, what kind of top end and hole shot are you getting with that set up?Last edited by grouper sandwich; 07-23-2012, 10:42 PM.
ÂÂÂÂÂÂÂ
