I have a 2006 F150 with 255 hours on it that is not shifting properly/at all. It seems to be stuck in forward gear right now. The throttle moves freely and so does the drive linkage. The linkage in the motor housing also appears to be moving into the proper locations for Forward - Neutral - Reverse too, but nothing happens. It's stuck in forward.
What's more strange is that the motor starts and stops with the turn of the key - perfectly, but it is in forward gear, so a start puts you into motion right away. Usually, the electronic safety will not let you start in gear, but this does.
The motor will go WOT in forward and reduce down to a fine idle too - like normal, but it won't shift out of forward. All other motor functions also work just fine and I have no warning lights or buzzers going off at all. Anyone have any ideas on where to start with this?
Thanks.
Splitshot
Thanks.
Splitshot
