Yahama j 1986
  • Yahama j 1986
    How to check the charging coil and pulses coils. Do you need to disconnect the wires from the CDI Unit. If so what should be the ohm readings be and does the flywheel need to be on.
    looks like you do not have a Yamaha service manual for your motor, get one it has all the info in it
