power trim & tilt unit
  • power trim & tilt unit
    Greetings: I have a 1996 Yamaha 90 h.p. Model# 90TLRU If you go to Boats.net and look this engine up and select (POWER TRIM TILT ASSEMBLY 1) I am trying to figure out where the air bleed screw is. Would it be reference number 70? My system is air bound and I need to get the air out. Your help is greatly appreciated. Thanks...
    There is no air bleed screw, raise up all the way, top off fluid, unscrew the manual release screw on side on trim unit and allow motor to go down all the wau, lift motor back up by hand and recheck fluid, repeat couple of times and retighten manual release screw.
      Where is the top off fluid location>?
      I'm going to add fluid to my C60TLRV tonight.....
      Thanks.
