I have a 1998 ox66 250 that will not start when its cold (first start of the day). I can spray some starting fluid in the intake and it will start right up and run fine after that. Once it is warm, it will start right back up again but if I let it sit and cool down again, it won't start without the starting fluid. HELP PLEASE. Where should I start looking?
1998 ox66 250 won't start
If primer pumps up firm then fuel is where it should be so maybe your compression is a problem or check to see if fuel electric pump is coming on and pressuring to spec
Compression, spark, timing, and fuel in the proper ratio is all that is needed
ÂÂÂÂÂÂ
