I have a 2008 F115 motor that is leaking quite a bit of oil when I run it and after I shut it off. It started off small and now leaves a pretty big sheen behind me. I can see oil running down the steering bracket assembly as well. This started as a very small leak and now is getting bigger. Im positive its motor oil and not gas. Any Ideas?
2008 F115 oil leak
well, I cleaned it up and could not find the leak anywhere on the block. There was oil running down the forward part of the lower unit and a little bit coming out with the cooling water on the left side of the lower unit when I ran it. After all of that, in a moment of weakness I hooked up the trailer and took it to the dealer. It can't be too expensive right? Hahaha yeah, I know better than that. Hope I get it fixed without having to sell the kids............
I bought the boat used. It had been setting for three years after the previous owner hit something. The allision caused a lot of damage to the hull and I think that kind of forshadowed the hidden damage to the motor. The lower unit had some dings and scrapes on it but nothing more than I would expect to see where I live. Like I said earlier, the oil leak started off small but rapidly became huge so I suppose the fact that I was using the boat made it bigger. I don't know if the previous owner ever used it after the damage was done. Oh well, After all BOAT stands for....Bring Out Another Thousand
