No power to engine
  • No power to engine
    I have a 2003 Century 2000CC with a 150 SX150B Yamaha engine. When I turn the key or try the trim nothing happens?? Last time I had the boat out (a month ago) it ran fine! Batteries are new, tried switching to both etc. nothing.... I have lights, horn, live well pump etc. Cannot raise engine with the button on the side of the engine either. Is there a fuse I'm missing? I looked at all the fuses on the fuse block and they are all OK.
    What am I missing?
    George
    pirate60@comcast.net
    There is a main, in-line fuse(about 20 amps) in a black plastic fuse holder under the cowl right near the throttle slide(on my 90HP)...check it out. Maybe you momentarily got the battery wires crossed up, and that's the fuse that blows!...easy fix!
      Thanks, I'm going to go check it out this afternoon. Hope it is that simple!!!!
