1986 200Hp speedometer does not work
  • 1986 200Hp speedometer does not work
    Hi
    Is anyone know where the speedometer connected and how does it work?
    I have the Seloc manual book and I did not find it.
    The Tachometer works .
    Thank you
    Doron
    Speedo tubing connects to gearcase and there is a small hole on front edge of gearcase that is the pickup, probably need to clean out that hole and tubing.
      That tubing could have been pulled loose or broken when the lower unit was last droped for water pump service...maybe drop lower unit to check tubing connections?
        Thank you I will check it up.
          Pitot hole
          I did not find the Pitot Hole, do you have a picture of it? thank you Doron
            Here is where it is,
              I just had my yami outboard at the shop for a water pump impellor replacement and the shop neglected to hook the tube back up and I was able to fish the tube out of the foot with a piece of solid copper wire and reconnect it.
