How to remove control handle?
  • How to remove control handle?
    2008 250 4-stroke with a DBW control handle has a bad trim/tilt switch.
    How does the handle come off? The pivot where a bolt might be holds the gear disengage button...
    Then how do I get the old button out?
    Remove the rubber cap over button in center of handle to gain access to screws.
      I've looked, but the push-button to disengage the gears is under the rubber cap...only thing I can see
        Here is diagram 2006 and Later 2-stroke Rigging Yamaha Outboard DEC REMOTE CONTROL 1 (SINGLE) Diagram and Parts
