Hey guys I need help. Thanks in advance. I have oil seeping through where the low oil sensor is on the tank. My oil sensor does work when its low. I want to know if all I have to do is replace the gasket?
oil sensor has a leak on my 2003 90 two stroke
anyone??? why does it have to be replaced if the switch still works? does the 10 cent creat a seal? looking on the diagrahm it doesnt call it a switch. calls it a oil level assembly gauge, oil strainer and cover along with a gasket? does the gasket go bad?
The old one must not be sealing and replaceing it should solve leak.
ÂÂ
