V Max 175 Electrical problem
  • V Max 175 Electrical problem
    when you hook the battery up it sparks with the key off. I unhooked the stator wire and it dont spark any more. I tested the wires comming from the stator and when you hook the test light to a positive power it lights up which is grounded. And when I hook the lead to a ground and test the wires going to the stator it lights up. This is showing that I have power on the wires (both) going to the stator even with the key off. This motor only has 47hrs. on it.
    Need to test voltage regulator may have bad diode.
