I have a 2010 yamaha 90hp four stroke I just got it out of the shop the injectors/ throttle body was clogged up I use the blue stabile is there any other additive that I can use to prevent this happening again thanks for any advice
Using boat every couple of weeks is the best solution, if you have the non-Ethanol gas available to you use it and fuel stabilizer along with changing out fuel filters on regular basis will make a big difference.
