I removed the PT/T pump. I put the new motor and need to bleed the unit. The manual states while it is out of the bracket push all the rods down (I guess by hand it doesn't state) put the unit on its side and fill the reservoir. connect the leads to a battery and make the unit power up and down several times while periodically checking fluid level. It never mentions a bleeder valve. Does it bLeed automatically. I guess I am asking if there is a bleeder valve? If so where is it? If not how is the air getting out? Just a little confused.
Thanks Tom
Thanks Tom
