I need help...it appears my shift linkage rod has pulled out from the black plastic piece inside the gear selector. How do i get the shift linkage rod to screw back into the piece inside the gear shifter?
This is a two part question as i am also trying to figure out how to adjust the shift linkage. How do you adjust the shift linkage...the reason i ask is because the reverse tilt lock is stuck in the down position and will no disengage when i want to put the motor up. It catches over the tilt stopper pin and wont disengage to take the motor up. I have tried everything (including pulling the shift linkage rod out of the black piece inside the gear selector....see top question. LOL.
Any insight into the two questions would be greatly appreciated.
Thanks in advance.!!!!
