115tlrc Rigging question.
  • 115tlrc Rigging question.
    I'm replacing the 1995 evinrude 112spl currently on my boat with a 2004 Yamaha 115 tlr 2-stroke. I want to make sure I have all the correct parts.
    Here's what I'm looking at;
    Single binnacle control - 704-48205-P0-00
    Single main switch - 704-82570-08-00
    Analog tachometer - 6Y5-83540-05-00
    Trim meter - 6Y5-83670-12-00
    Volt meter - 6Y5-83503-00-00
    Fuel gauge - 6Y7-85750-10-00
    Main wire harness - 6X3-8258A-00-00
    Are these the correct components? What throttle and shift cables do I need? How are they measured? What hose do I need to connect the remote oil tank to the motor.
    All I have is the motor and oil tank. Am I leaving anything off of my list?
    Will also need
    68F-82553-50-00 Trim/oil harnees to connect gauges to engine
    6Y5-83553-N0-00 Gauge power harness to connect gauges to key switch
    and two MAR-CABLE-xx-SC(replace xx with cable length) shift and throttle cables.
