Hello, my 50 HP two stroke is acting up again.
A bit of history, Last year, boat ran great at 35MPH with outboard turning at 5500 RPM. About 6 weeks into last season, RPM maxed out at 4500 and top speed around 25MPH. Had the carbs cleaned and was back up to 35MPH and 5500RPM.
At the end of the season problem started again, dropped to 5100RPM max and 28 MPH. I figured since the carbs had been cleaned it must be something else, replaced all fuel lines inside cowling and new fuel pump ( OEM).
Put the boat in the water yesterday and RPM still topped out at 5100 and top speed 25 MPH. short period of time later after some low speed running I was only able to get to 3000RPM max and speed that wouldnt even register on the tach. I pulled the plugs and the top two had a lot of carbon (even though they were cleaned after the spring fogging oil burn off) and the bottom plug was wet and smelled of fuel.
Prior to putting boat away for the winter I fogged the cylinders, drained the carbs, filled the fuel tank with stabilized fuel, changed the gear oil ( no water), replaced fuel filter element and replaced 10 Micron fuel water seperator.
;ast week ( prior to using boat) I pumped all of the old (storage fuel) out of the tank and filled with ethanol free fuel ( 91 octane as its the only non ethanol I can get).
Is it the carbs again or could it be something else?
-Spark tested and good
-Compression 120 PSI on all three cylinders.
-Timing was checked last year when I had the problem and was found to be good.
