In the course of homebuilding my boat, and before buying the motor, I purchased on-line and installed a Yamaha Multifunction Digital Tachometer with harness. The harness had TWO 4-wire connectors at EACH END. The color coding and connectors of the harness matched those of the tach. A few months later, I bought a new Yamaha T60 High Thrust 4 cycle. When I got the motor, it had only one 4-wire connector to plug into the harness. The tach worked, but not the trim, oil or temperature.
The dealer told me that the new motor fed all the data through just 4 wires now, and I needed an adapter harness to make the existing tach work. I purchased this and installed it. This added the trim indicator, but I still have no oil or temp reading. The dealer's service department doesn't seem to know what is wrong.
