Hi, I've got a pair of F225TXR with standard Yamaha gauges. I also have a Garmin plotter (4208) and NMEA2000 network. Can I include engine data from the 225's into my NMEA2000 backbone network to display engine data on my plotter (fuel consumption, alarms, RPM etc) and if so what engine interface / connectors would I need? Many thanks
Yamaha F225 to NMEA2000 network
If you have Yamaha Command Link gauges then can install MAR-GTWAY-ML-09 Gateway to link Command Link network to NMEA 2000 network.
I do not believe these are the Command link gauges, I think they're the standard digital gauges that were supplied with the 2006 F225 Yamaha's. Also, I would like to change the multifunction gauge to metric units. Do you know what the dip switch settings should be to get L/hr (instead of gal/hr). Thanks.
Here's a pic of the one Port tacho gauge.
Edit, just checked the owners manual and the gauges are Command LinkAttached FilesLast edited by Seafari1967; 06-06-2012, 11:27 AM.
That picture is a Command Link gauge, the owners manual should have instructions for resetting menu for units of measure.
ÂÂÂ
