Timing for T50TRLX 4 stroke
  • Timing for T50TRLX 4 stroke
    Purchased used motor; seller advised it was running rough, seller took it to jackleg mech who advised it had blown head gasket; Mech stripped out several head bolts; mech used helicoils; (1) helicoli did not take; seller refused to pay and picked up motor; Carbs, timing belt currently removed from motor; I want to conduct compression test before sinkin a lot of money in motor; I lined up driven pulley with mark on head; can't see timing mark on driver pulley without removing flywheel; I do not own special tools to remove flywheel; I am confident that flywheel has never been removed: Can I remove the #1 spark plug and rotate flywheel to TDC and then put timing belt on and run compression test without fear of damaging the valves?
    That year model motor is non interference engine but I would remove flywheel and set timing correctly before doing any more to it.
