After running my 2001 225hp Yam in the driveway for about 5 mins, the hi temp alarm goes off. I changed the two thermostats, impeller, and PRV (poppit valve) without any luck. The alarm still goes off after about 3-5 mins idling at 800rpm's (again while the boat is on the trailer in the driveway). I haven't checked the thermoswitches as it seems the odds of those going bad are too low. The tell-tale stream seems at an appropriate rate/force while idling at the low rpm's. Any suggestions or ideas would be greatly appreciated, thanks!
hi temp alarm 2001 225 Yamaha
