Recently pulled power head and rebuilt lower unit to free the shaft up. Motor has new impeller and water pump gaskets. I took off the thermostat housing, water is gushing out of that (the tube is lined up). I pulled the cooling water pilot hose, water gushes out of that. I pulled the cylinder head off, it's all clear. When I blow air into the small hole (left side) inside the thermostat chamber, air blows freely out of the piss hole on the back of the motor. I know there is plenty of water flowing through the engine, but can't figure out why it's all going out the prop and not mixing with exhaust / pissing out correctly? This is my first time overhauling an engine (of any kind) - it's starting on the first pull, running well... but it's not working as intended and I feel like I've missed something obvious? Thanks.
1991 15 hrs will not piss
Originally posted by johnmarcous View PostI took off the thermostat housing, water is gushing out of that (the tube is lined up). (impeller seems to be doing its job)I pulled the cooling water pilot hose,(what is that?) water gushes out of that. I pulled the cylinder head off, it's all clear. When I blow air into the small hole (left side) inside the thermostat chamber, air blows freely out of the piss hole on the back of the motor. I know there is plenty of water flowing through the engine, but can't figure out why it's all going out the prop and not mixing with exhaust / pissing out correctly? This is my first time overhauling an engine (of any kind) - it's starting on the first pull, running well... but it's not working as intended and I feel like I've missed something obvious? Thanks.
I am running in a 55 gallon barrel - not muffs. I am not 100% sure what the tell tale is - but I think the manual calls it the pilot hose (off the side cover) and it's got a strong, steady stream of water coming out.
what motor are you speaking about?
If you are worried about water coming out of the idle exhaust relief ports, my C40 does not have any coming out either. I worried about it at first as all of the Johnierude motors I had owned in the past always had a lot of water flowing out of them. But looking at other Yamahas they only had a mist coming out if any at all.
Sorry, I thought the title said 15 hours
Had not seen HRS as a model # before
Might want to see if you can look at other 15s to see what they put out to be sureLast edited by 99yam40; 05-09-2012, 08:35 AM.
ÂÂÂÂÂÂÂÂÂ
