Please clear confussion on which Digital Multigauge Speedometer. The motor is a 1999 OX66 SX150 fuel injection. The current speedometer is the model # 6Y5-83570-S4-00 which is working but has faded so bad it can barely be read. Bought a new 6Y5-83570-S5-00 after being told that was the new part number and would work. The wires were a perfect match...unplugged the old and intalled the new. All I got was the "Err" message on screen. Unplugged the new, replugged the old and it worked and read correctly. Repeated 5 or 6 times with same results. QUESTION: is the S5 really the correct replacement for the S4...and what could be the cause of the "Err" message? Help please...and thank you for any knowledgable advice.
Which digital speedometer for OX66
Thats the correct part number, Check wire connections and dip switches are set correctly.
Are you sure the red and yellow wires are connected to gauge? If so then probably a bad gauge.
ÂÂÂÂ
